xoomer Posted September 27, 2012 Share Posted September 27, 2012 Hey, So What's the Deal with Axles? I've put 3 sets of O'Reilly New, one Set of Autozone Axles, and a set of Napa Axles. All I get is Clickity Click click. Its all intermittent and kind of getting on my nerves. I know this has been covered before but my Search-fu is not good. Quote Link to comment Share on other sites More sharing options...
ShawnW Posted September 27, 2012 Share Posted September 27, 2012 You have managed to install all the kinds that I know of that are habitual clickers so far. I will PM you some pricing on good axles. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted September 27, 2012 Share Posted September 27, 2012 I've had excellent luck with EMPI, even on lifted vehicles. Quote Link to comment Share on other sites More sharing options...
O.C.D. Posted September 27, 2012 Share Posted September 27, 2012 But where is the good source for the EMPI axles? Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 27, 2012 Share Posted September 27, 2012 So What's the Deal with Axles? haven't you seen all the axle threads - nearly anyone that spends time with a wrench knows that aftermarket axles absolutely suck. i thought for sure you would have seen that? they are time suckers, i learned the hard way. here's the two solutions in my book: 1. Get Subaru axles and reboot them 2. MWE (probably who shawn may be quoting you, they are geographically close?) It's annoying and a little extra effort but if you're not lazy and have some synapses still firing it'll save you a lot of headaches. Folks do seem to suggest good results with EMPI, failures have been reported, so to me that's not conclusive enough to avoid the 100% (for me) solutions noted above. Though I can see the attractiveness of having an aftermarket supply for folks that own their own shops, do this for a living. Quote Link to comment Share on other sites More sharing options...
jboymechanic Posted September 27, 2012 Share Posted September 27, 2012 But where is the good source for the EMPI axles? ebay, partsgeek.com, rockauto Quote Link to comment Share on other sites More sharing options...
TajMan Posted September 27, 2012 Share Posted September 27, 2012 Just had horrible luck with an autozone duralast rebuild, I've got a new duralast gold coming now that is supposed to be 100% new, we will see. I think it was my passenger's side which needs it anyway, but when I installed the rebuilt unit on the driver's side barely...it clicked like MAD even when going in a straight line! I was shocked and appalled, even after expecting it to be 'bad'... it was REALLY bad Quote Link to comment Share on other sites More sharing options...
skishop69 Posted September 27, 2012 Share Posted September 27, 2012 Strange, I've used NAPA axles on all my Brats for years and never had an issue. And if there's anyone who lives the 'Drive it like you stole it' motto, it's me.... Quote Link to comment Share on other sites More sharing options...
xoomer Posted September 27, 2012 Author Share Posted September 27, 2012 Well, O'Reilly's is going to Refund me on the axles and I'm going to put a Rebuilt set in my Subaru from My local suby shop. Quote Link to comment Share on other sites More sharing options...
xoomer Posted September 27, 2012 Author Share Posted September 27, 2012 haven't you seen all the axle threads - nearly anyone that spends time with a wrench knows that aftermarket axles absolutely suck. . I know, But I Work in Parts for a different brand and we use the aftermarket for axles all the time. and we havn't had this problem. but we are talking KIA and Nissan. I thought I'd give em a shot. Quote Link to comment Share on other sites More sharing options...
ferox Posted September 28, 2012 Share Posted September 28, 2012 The only cheap aftermarket axles worth messing with are the ones that are new not reman. I have had great luck with them, but one thing I have noticed is the grease is all in the boots from the factory. It makes sense. An assembly line is not going to get messy squishing grease into the bearings. I am sure they assemble everything and before they put the last band on the boot, they slide a needle fitting in under the lip, squirt and band. If you don't spend some time and effort mushing the grease into the bearings before install, then the bearings are basically just running with a little assembly lube or dry. I have had one set of OPs come bad out of the box, but that's it, they had a one year warranty, I took them back and then no problems. Empis have never given me problems. Axle quality has been debated many times of course, but GD mentioned massaging the grease from the boot into the bearings on the new aftermarket axles a long time ago. I have done it every time since then, and had great success with many sets on multiple cars, so that makes me think the boot grease massage is an essential factor on the new aftermarket axles. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted September 28, 2012 Share Posted September 28, 2012 I know, okay, i figured you did as much subaru stuff you do and i knew you had worked in car parts places before. the grease massaging sounds interesting. Quote Link to comment Share on other sites More sharing options...
