September 29, 201213 yr I've noticed I can adjust the ride height on via the front struts by about an inch, but I can't identify a similar adjustment in the rear. Is there one hiding under there somewhere?
September 29, 201213 yr It's a single bolt on the top of the rear suspension tube in the center, pointing up at the bottom of the body. Somewhere close to the front of the rear diff I think.
September 29, 201213 yr Author Do you have a pic or a diagram? I've been looking all up under there and haven't found any bolts visible on the centerline.
September 30, 201213 yr The adjustment bolt is on the Gen 2 models but not the Gen 1's... You can still adjust the rear ride height by re-clocking the torsion bars on each side.
