adrianscott Posted October 16, 2012 Share Posted October 16, 2012 have a subaru leone for 2 years now, finally got it started but when i try to move, it only goes forward, it goes forward in every gear, park,reverse, and even in neutral :mad: i really need some advice asap. thnkx Quote Link to comment Share on other sites More sharing options...
naru Posted October 16, 2012 Share Posted October 16, 2012 Sounds like a valve body problem if the cable is OK/adjusted. Quote Link to comment Share on other sites More sharing options...
adrianscott Posted October 17, 2012 Author Share Posted October 17, 2012 Sounds like a valve body problem if the cable is OK/adjusted. okay, could i get a little more details on this, i rebuilt the engine myself so i think i should be able to work on the tranny too. its the 4wd transmission (not full time 4wd tho) Quote Link to comment Share on other sites More sharing options...
djellum Posted October 17, 2012 Share Posted October 17, 2012 seems simple, but did you check the mechanical connections underneath? if they have come loose or off of the actual shift lever it wouldnt change gears no mater where its at. Quote Link to comment Share on other sites More sharing options...
adrianscott Posted October 17, 2012 Author Share Posted October 17, 2012 seems simple, but did you check the mechanical connections underneath? if they have come loose or off of the actual shift lever it wouldnt change gears no mater where its at. oh okay, ill check the connection, maybe its loose as u said but its connected tho because i see when it moves Quote Link to comment Share on other sites More sharing options...
adrianscott Posted October 27, 2012 Author Share Posted October 27, 2012 park and neutral working now (seemed as if it fixed itself) but not getting any reverse still.... any suggestions? Quote Link to comment Share on other sites More sharing options...
AKghandi Posted October 27, 2012 Share Posted October 27, 2012 drive the snot out of it! get the gunk out of the valve bodys. maybe try the sea-foam trans tune. if it sat for a while it probably just needs to stretch its legs. Quote Link to comment Share on other sites More sharing options...
adrianscott Posted October 29, 2012 Author Share Posted October 29, 2012 yeah thats what i realised, thats what i did then the park and neutral started working and yeah it was parked for 9 years. tomorrow ill go take a step in it Quote Link to comment Share on other sites More sharing options...
