Help with Sedan EA82. Can't remove plastic cover...
Hi, I have a sedan EA82 and I have a problem removing the plastic cover that you can see in this photo on each side of the rear window. Can you tell me how the heck I can remove this cover without breaking it?
Thanks
Edited by KristjanJohann
Those trim pieces Slide to unlock. I believe they need to move upwards. Even then, it's no guarantee that the fasteners won't break. Good luck.
Like he said, mine broke, I still need to find a nice EA82 sedan to get new ones off of so I can paint them so they look good again :clap:
  • 2 weeks later...
I went by the yard today and had an opportunity to remove a couple of these back window trim pieces. And it is true that you need to slide the trim piece upwards to unlock and remove. But, first you must pop the lowest fastener loose the same way you pop a door panel fastener loose. Then the whole trim piece can easily be slid upwards and removed.
Curious, what did it cost you?
Thank you so much, now I just have to cross my fingers and try it on mine
