November 15, 201213 yr I replaced my trans on my 95 legacy awd and the one i put in had the speed sensor removed from the wire harness I need to know where the 3 wires go in the harness. Its the speed sensor at the rear of the trans. Ive look every where and cant find anything that shows the brake down of that Wiring Harness.
November 15, 201213 yr Anything here? http://www.google.com/search?q=wiring+schematic+95+legacy&hl=en&tbo=u&tbm=isch&source=univ&sa=X&ei=QjmlUOfpLrS30QHFzYGwDA&ved=0CDgQsAQ&biw=1152&bih=680#hl=en&tbo=d&tbm=isch&sa=1&q=transmission+wiring+schematic+95+legacy&oq=transmission+wiring+schematic+95+legacy&gs_l=img.3...85038.88852.0.90667.13.13.0.0.0.1.120.1287.8j5.13.0...0.0...1c.1.A_DaiGCiUT0&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.&fp=5a338a50b408abf7&bpcl=38625945&biw=1152&bih=680 or here? http://www.google.com/search?q=wiring+schematic+95+legacy&hl=en&tbo=u&tbm=isch&source=univ&sa=X&ei=QjmlUOfpLrS30QHFzYGwDA&ved=0CDgQsAQ&biw=1152&bih=680
November 16, 201213 yr Have to apologize since when I looked closer at those two links, there is a bunch of junk as well. A member "Gloyale" offered in an earlier post that he had a pdf of the 1995 wiring he got from pdftown.com Suggest a friendly request via the board or email. or download the zip file here: https://rapidshare.com/#!download|934p11|368636446|pdftown.com_SubaruLegacy1995.zip|69347|0|0 Hope this helps.
