front wheel bearing?? 1996 1999 lgt wagon...
anybody know if a 1996 legacy outback front knuckle is the same as my 1999 legacy gt? my wheel bearing has been making noise for a while and i found a low milage 1996 outback and thought i would use it to press a new bearing into then throw it on my car. this way i can take my time about it..will it work and go right on? thanks! my lgt has 235k and i beleive these are the stock front bearings? could that be right? both rears went out and replaced at about 210k..
Yes, the same. Just make sure you have the same ABS Sensor location and you will be all good.
