February 5, 201313 yr Ok so i was diggin through my dads old shop looking for a throw out bearing for my 90 legacy sedan, which i found, and came across two big boxes of subaru oem parts ranging from sensors to pistons to so many things some i dont even know what it is. I believw it to mostly be gen1 parts but could be gen2 as well. if anyone is curious ill be happy to spend thw time tomorrow cleaning the atuff up and taking pics along with making a list of known items and inquiring about unknown thru pics and part numbers. most parts are even still in oem packages. looking to sell what i cant use so please if interested lemme know and ill take the time.
February 5, 201313 yr Author Ok well im gonna gather up the rest of the parts and sort through them. i hope to have pics up by tonight. if not then it will be yomorrow.
February 5, 201313 yr Author Ok got pics and small list of some of the bigger items. Gonna do more research into the box of sensors switchs gaskets etc. that is all later. 4Sub emblems 3 Sub light cases sd protector rh & lh sub light lens liscence plate illuminator sub lighter kit sub computer 83 not sure what Nicron air filter 2-5801 Piston and pin ea71 7 valves 5 koyo ball and roller bearings 1 NSK bearing Bag of steel balls (im assuming for a bearing or something) 2 sub ring-syn sub coil cover sub ball brg sub ndl brg gear dist drive pulley 4 lug rotor 4 matching brake pads 3matching brake pads Brake caliber 2 amsoil spinon bypass oil filters mdl# BE-90 Crank bearing set sub a/c receiver drier clutch cable http://m1285.photobucket.com/albumview/albums/wrtsubaru/2013-02-05_165542_zps40c698a5.jpg.html?o=2 ok thats the list i got so far. when i figure out how to post pics i will do so. and as for prices i have no idea what any of this is worth so shoot me a number. Two things though, make the offer worth it and you cover shipping. i want to make a little money as does eveyone but my main reason for this is to POSSIBLY help another soobie owner. the parts were sitting around and i hate for it to be a waste. everything is sold AS IS you get it dont like it im sorry. i will take closer pics of parts as requested. Edited February 5, 201313 yr by southgalegacy
February 6, 201313 yr How much for the whole lot? How big of a box is it and how much do you think it wieghs altogether? -Bill
