1992 BC5 GT Legacy
Hello all,
I have a BC5 Legacy which I am currently running a TD05 Turbo on. Recently I picked up a manifold and split fuel rails from a GTB Legacy and am looking at installing it into my car. The fuel rails have the yellow top injectors from the GTB in them. What problems can i expect to run into or will this just be a straight swap and away I go? I'm still learning about all this so any help would be much appreciated thanks.
Further from this, just to pick someones brain, I have been having a issue randomly pop up once every few months where when I turn the key nothing happens. If I walk away for 5mins then try it again it starts first pop. Past this sometimes I have to have my key turned for 3-4seconds before the car turns over/does anything. I'm sure someone must have some insight into this, in the last year I've had a new barrell put in the car and had my coil pack replaced.
Also recently the cars revs will sometimes drop a few hundred then come back up when it is below 2k revs driving along, but is fine if your above 2k. At times it dies when you slow down and stop and soemtimes when driving it will start running rough and sounding terrible. When this happens I will pull over and stop the car, when I go to restart it doesn't sound healthy but with a bit of gas it starts back up and will run fine from then on. I've been told I need to look at replacing my AFM/Knock Sensor and Cam/Crank Sensors but I just thought I'd ask if anyone else has experienced something similar before.
Edited by hurro
5 spd or auto? mine does this sometimes when the trans lock isnt quite engaged and my rs did it because the clutch saftey switch went bad
it is an auto 1992 GT Legacy. Just figured someone might know something, my research has got me no where.
Starting issue is probably worn contacts in the starter solenoid. Pretty common issue to all Subarus. There was a thread about replacing them just a few weeks ago with links to a parts supplier.
Stumbling and stuttering at low RPM is almost always spark plug related. If it hasn't had new plugs in a while, it's worth the $15 to get new ones in. Turbo engines are hard on spark plugs, and they often get carbon fouled in cold weather.
Fuel rails I can't say one way or the other, but there are some people on LegacyCentral.org who can probably answer any questions you have about it.
