April 27, 201312 yr Did the cable brake or is the cable end OK and just the plastic pull tab broke? The cable can be changed by removing the drivers front fender.
April 28, 201312 yr Just replace the plastic part if its broken or just put the cable back in. Make sure you lube the hood latch.
