Code po440 Evapmalf, p1441 evap vacuum cut valve
I know this has been discussed before, but I have a 97 Impreza with the check engine light on. I keep getting the codes po440 evap malf and p1441 evap vacuum cut valve. I can clear the codes, but they just pop up again later. It hasn't caused me an issues and mechanics haven't been able to solve this. Is this something that is an easy fix or a bigger project I should be worried about?
  • 7 years later...
