May 20, 201312 yr While poking around my engine bay, I found that the wiring to this sensor was severed. Problem is, I can't figure out what sensor it is. Going to be fixing it soon, just need to run to the junkyard to grab a connector off another EA82T and splice it in. It's the sensor circled in red. Behind intake, next to bell housing. Knock sensor?
May 20, 201312 yr Author Thanks. I was looking at a GL-10 at the local junkyard, which also had an EA82T, and it didn't seem to have this sensor. Seems odd that different generations came with/without a knock sensor.
May 20, 201312 yr the knock sensor is more slim... but also is the only electronic cable that belong to that part of the engine....
May 20, 201312 yr 85/86 flapper MAF type use a 2 wire Knock sensor. Round connector 87+ Hotwire MAF uses a one wire. slim round connector The CTS is in that area too. square 2 wire
