2002 wrx all cylinders misfiring
 Accesport keeps coming up with all cylinders misfiring, what to do?
 2002 Wrx
Mods:
IHI VF30 19psi
STI 550cc inj
APS cold air w/K&N filter
Samco MAF hose
Perrin turbo inlet hose
APS Front mount intercooler
Walbro 255lph fuel pump
PDE catless downpipe, uppipe and highflow cat
step colder plugs
Edited by smr6879
Has the car been tuned professionally on a dyno?  I assume you have it on a basic stage 1 map?  19 PSI is awfully high if you haven't had a dyno tune done.  Do you have an AF gauge so you know where you are in the stoichometric level?  14:1 goal and I bet you are real rich with those mods and have fouled plugs.
P0301,P0302,P0303,P0304 are the codes im getting, the previous owner said it was tuned by P&L motorsport in IL
My initial thought is fouled plugs because of the colder heat range, WRX runs cold plugs anyway, I don't see any need to have them even colder. Try a set of stock plugs first.
Second thought is the MAF sensor could be covered in oil from that K&N.
i got the codes to go away by changing the map, my 02 wrx over revs when boosting after i went to the drags. Would that be my clutch? Stage 1 exedy, previous owner says he had it put in at 80k now has 125k
