How to hook up Alternator wires?
wish I could help.. The stocker the GM and the Maxima alt are only two wire.. I am going to assume you need one of those plugs going to ground the other two are the one to splice into the stock plug..  Someone will be able to accurately answer though.
I do have the stock plug for the 2.2T alt so if anyone knows how to do this?? Where's General Disorder? He would know! Anyone????
Black/white wire of the EA to the Yellow wire of the EJ plug.
White/Red wire of the EA to the Black/white wire of the EJ plug.
Big white EA wire to the charge terminal.  You may want to run a new wire back to the Fusible link box, or at least replace the last 6-12 inches of wire with new and a new ring terminal.
