SubieBrat Posted June 25, 2013 Share Posted June 25, 2013 I just finished putting in a 5-speed for my brat. I go to start it and it starts imidiately but then wants to die. It sounds like something is hanging up, I think it is the starter but I don't know for sure . The transmission is in nuetral. Are the starter motors for the four speed and five speed different? or does anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
capn_r Posted June 25, 2013 Share Posted June 25, 2013 Put flat washers between the transaxle and starter to slightly space the starter back so the drive gear clears the flywheel gear. I don't know what to tell you on the engine wanting to die. Quote Link to comment Share on other sites More sharing options...
LPGsuperchargedBrumby Posted June 25, 2013 Share Posted June 25, 2013 i had the same problem when i swapped to the 5spd....and spaced the starter out with as large diameter washers as i could fit......if the engine is cold and trying to drag the starter along with it, it will want to die and not idle Quote Link to comment Share on other sites More sharing options...
SubieBrat Posted June 27, 2013 Author Share Posted June 27, 2013 Thanks for your help guys, it worked great. My brat runs better than it ever did. Thanks again Quote Link to comment Share on other sites More sharing options...
jono Posted June 29, 2013 Share Posted June 29, 2013 Good. I made notes when I did mine. Used 4.0mm thick aluminium plate to make a ringed spacer, rather than just washers. Emphasis on this post is the 4.0mm Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 30, 2013 Share Posted June 30, 2013 Did you use the EA82 flywheel? Quote Link to comment Share on other sites More sharing options...
