Freeze plug size needed
Hello,
I have a 1982 GL wagon with a 1800 that has a leaky freeze plug under the valve cover.  I'm not having much luck with the local parts guys and I hope someone here knows the size of the plug needed.  Should I just try to press in the old plug or replace with a new?
Thanks
I wouldn't reuse unless it was your only option.
I do not remember what size they are, just that when I blew 2 of them out all I had to do was take them in to a local auto parts store (NAPA) and they quickly matched it to a common core-plug from Dorman.
If you have a reasonably non-deformed old plug in hand, a decent parts store should be able to help.  If they are not competent enough, ask them to let you look through their drawers of Dorman parts (or equivalent supplier); match the outside diameter and you should be good.
IIRC, you should coat the edge with Loctite (red???).  I could be wrong on this, so research a little.
have had this problem...
decent parts store is not enough....
went to 3 parts places and a couple indusrial suppliers
they are 20mm
i had to go to a subaru dealer that knows about old gen soobs
the nearest dealer is useless
i can give you details if you like - i'm sure they could ship
Use a new one.
Subaru 11051AA010.$2-$3
If 20mm is corect,there are aftermarket ones.
Dorman 555-101 or NAPA 381-2151
Dorman ones are on ebay if no one local has them.
Thanks guys!  I live on a rock in the middle of nowhere!  Trying to find anything here is a beooch!
