July 12, 201312 yr I was just wondering I swore I saw something where they were listed in inch pounds but I'm seeing here 7.2 & 14.5 FT.lbs maybe I used a inch pound wrench.. Do you guys use a beam or clicker for this area? I ended up before using a inch pound wrench since my lowest only goes to 10.
July 12, 201312 yr I've used both. CLickers I don't think are that accurate at such low ratings. And it was after I had snapped 2 bolts not realizing there were 2 different torque settings. IIR one for the 4 beefier bolts and one for the 2 closest the cam seal. On the plus side I did get me a spiffy new set of small EZouts! Still sucked!
July 12, 201312 yr Author I've used both. CLickers I don't think are that accurate at such low ratings. And it was after I had snapped 2 bolts not realizing there were 2 different torque settings. IIR one for the 4 beefier bolts and one for the 2 closest the cam seal. On the plus side I did get me a spiffy new set of small EZouts! Still sucked! seems like I would be better off with the inch pound wrench again.. (it walked off) it's a 20-200 in.lb range suck having to buy another but oh well..
July 12, 201312 yr I downloaded the FSM from a link from a member and I had notes in the garage on the head bolt torque sequence and lbs and cam cap specs.. I haven't done one recently enough to remember what they are.
