August 8, 201312 yr Author also thinking of throwing on the snow tires that came with the wagon and seeing how it does at tahuya with no lift.
August 9, 201312 yr Tahuya will probably be just right, except rubbing your exhaust. Just wait. You don't want to break it before you even get it lifted! Patience man, patience.
August 9, 201312 yr I have a brand new unused 2" BOSS lift that I'd sell if you're interested. I'll let it go for what it cost me, $125 shipped and PayPal'd.
August 9, 201312 yr Author Not sure if I want a 2" lift on a daily. I read to many stories about axle issues...
August 9, 201312 yr Not sure if I want a 2" lift on a daily. I read to many stories about axle issues... I have DD's many 2" lifted EA82 cars with no issues at all. And mine were never even camber correct like this one. But totally your call!
August 11, 201312 yr a 2" is not going to eat axles on a daily driver. If it does you did it wrong.lol
August 12, 201312 yr I like 2" strut top with a 1 1/4 drop on the crossmember and trans support.......Reqiures longer coupler......one from Legacy Outback. In fact you can get the crossmember spacers and the trans spacers too. The trans spacers are painted to the crossmember, but will come off with a bit of persuasion. Also with a 2" lift either way you are running your angles steeper......so take clip the inner CV joint, small clip....and slide it up the shaft past the padding, and reclamp it. This will help keep it from tearing since it will be running at a steeper angle all the time now.
August 13, 201312 yr Author Word. If I bother with a body lift I'll just go for a 4" suspension with 3" body. Still not sure though. I need to worry about rebuilding the carb or finding a cheapish weber. Anyone have experience with the ea82 carb kits other than the walker version?
August 14, 201312 yr Word. If I bother with a body lift I'll just go for a 4" suspension with 3" body. Still not sure though. I need to worry about rebuilding the carb or finding a cheapish weber. Anyone have experience with the ea82 carb kits other than the walker version? What's wrong with the walker kits? That;s what I always use. All you really need from it are the little airhorn O-rings, The top gasket, and the Accelerator pump. Maybe the needle and seat too. Easy to cleanout and rebuild in the car, just the top needs to come off.
August 14, 201312 yr Author http://www.oreillyauto.com/site/c/detail/WLK0/15853A/02447.oap?year=1987&make=Subaru&model=GL&vi=1268467&ck=Search_carburetor+kit_1268467_3689&keyword=carburetor+kit is this the right one?
August 17, 201312 yr http://www.oreillyauto.com/site/c/detail/WLK0/15853A/02447.oap?year=1987&make=Subaru&model=GL&vi=1268467&ck=Search_carburetor+kit_1268467_3689&keyword=carburetor+kit is this the right one? No that's the one for the EA81, hitachi model DCP-306 you need the one for ea82 Hitachi model DCZ328. This onehttp://www.oreillyauto.com/site/c/detail/WLK0/151051/02447.oap?year=1987&make=Subaru&model=GL&vi=5012099&ck=Search_carb_02447_5012099_-1&keyword=carb&pt=02447&ppt=C0359 Edited August 17, 201312 yr by Gloyale
August 20, 201312 yr Author After taking off the carb I noticed no coolant in the overflow... Took the rad cap off bunch of white crap in there. And this starting flowing out on the intake Mani.. That is not normal ....
August 21, 201312 yr Its an EA82 engine.Of course it is normal lol that sucks man. hope ya get it fingered out. cheers
August 21, 201312 yr Author Its an EA82 engine.Of course it is normal lol that sucks man. hope ya get it fingered out. cheers yea i have learned i definitely prefer the ej motors haha not really surprised though. atleast it was cheap. have a chance to buy an impreza so i might see if someone wants the gl as is
August 22, 201312 yr After taking off the carb I noticed no coolant in the overflow... Took the rad cap off bunch of white crap in there. And this starting flowing out on the intake Mani.. That is not normal .... It actually is normal for there to be coolant there. It looks a bit watery, not enough coolant in it but otherwise that IS normal. Many people fill that passage with JB weld to stop potential leaks from the carb base.
August 22, 201312 yr Author Hmm. Even though it is consuming coolant and all of it is this color? Sludge in the overflow too.
September 11, 201312 yr Author alright starting think about just fixing the gl since no one wants to buy it as is. maybe ej swap? or swap on a weber and hope the HG actually arent blown? i really need a car for work and i dont want to drive the ej20g swapped wagon even though it is running now. anyone have a weber setup or a sjr flywheel and adapter plate?
September 11, 201312 yr If you are gonna hope the HG aren't actually blown, then why not put the hitachi back on? They are super easy to clean out and reassemble. You got the kit, why not give it a try? The "coolant" looks more like water with a slight mineral content. Not much green coolant there. Sludge could be from watery mix or Orange coolant mixed in at some point. With a mixture this watery, it's probably reaching close to boiling, overpressurizing, and steaming off. That would explain loss of coolant. It is not enough to just run water. It will boil, steam out, and corrode the engine while it's at it. Don't make any cooling system judgements until you have run it with a correct mix, fully burped. So for that reason I would at least give the carb rebuild a try. See if it runs better. It will get is sealed and running again for diagnosisi, and even if the HGs are blown, you will have the carb running good so you can do the HGs and go. The carb and the HGs are really seperate issues, so don't make decisions on one based on the other. Edited September 11, 201312 yr by Gloyale
September 11, 201312 yr Author when i took the carb off and opened it it looked brand new. the pieces looked of higher quality then the ones on the rebuild kit even. if anyone local wants to help me put it back together hit me up. i would want to atleast eliminate some of these vacuum lines since i forgot where some of them go anyway. ive looked for threads about this but all of them have dead links since they are from the old boards...
September 13, 201312 yr There is probably a vacuum diagram under the hood. I would get it running and take it to Subaru for a coolant flush. They MAY not do it for you .But aS clean as that car is, I would give it a shot. That way you totally get the right coolant in there. And done by a tech. Or you could just let me trade it out of you. cheers
