July 22, 201312 yr my 1996 outback will not start. As I was driving yesterday it quit running. Im getting gas (pulled the gas line off and cranked it over gas came out. I also sprayed some starting fluid in the intake. I have spark @ the coil.. It turns over good no back fire. any help 235000 miles on it I changed the timing belt last year and I can see that its turning..
July 22, 201312 yr Having the engine die while driving isn't a good thing. You appear to have fuel and spark so I have to wonder if the valve timing has slipped since you stated the timing belt appears to be intact. The results of a compression test will tell you the story about that. I think that car has a non-interference engine and if that is what has really happened that would save your rear end.
July 22, 201312 yr Author Thanks would it easy er to pull the front of the engine apart and pull the covers to the belt? I did put a new belt on last year with new pulleys and water pump. Thanks
July 22, 201312 yr Checking the error codes is a good easy thing to do. I suggest you check the compression first before removing the belt cover. It might save you some time if the results show no trouble with the compression.
July 22, 201312 yr Author Do I need a specific compression tester for this? and what should the compression be? Thanks
July 23, 201312 yr No special tester is needed to do the testing. I'm not sure what the specs are for a nonturbo engine but I would guess you should see between 150lbs to 180lbs of pressure on a good cylinder. Hopefully all the readings are within 10lbs. of each other.
July 23, 201312 yr Author well I pulled the first plug out and did the test...And no compression guess the engine is gone!!! Guys is it worth the time to do a rebuild? It had 235000 on it.. Thanks for your time Dave.
July 24, 201312 yr I assume there was no compression because the timing belt has slipped. There might be a problem with the belt tensioner. I also assume that the valves weren't damaged. If that is the case then replacing the timing belt and other things may be worth the time and small investment for new parts. You need to decide that. If there is valve damage then that would really hurt. I would invest in a newer car myself but that is just me.
July 24, 201312 yr If this 96 has an automatic tranny, then it has the 2.5 motor. If the belt broke, or tensioner locked up, then the valves are damaged, so no compression. That being the case, then I am sorry, but it is bad news. If on the other hand, the 96 has the 2.2 motor with 5 speed, then that motor is non interference, so valves are not damaged. Simply replacing the timing belt with new tensioners will put you back on the road.
July 24, 201312 yr Author I can see the belt turning. When trying to start. This is 2.5 and I was driving going about 50mph at the time. So I'm thinking the valves are damaged. Because the belt is turning! Is this what you guys think? Thanks Much Dave
July 24, 201312 yr Pull the timing cover and line up the crank and compare marks. You don't have to take a ton of stuff off to do that. Accessory belts, AC tensioner, and crank pulley and you can remove the center cover.
July 24, 201312 yr I forgot about the differences between the 2.2 and 2.5 liter engines like Rooster2 mentioned. Your engine has major work required to fix it. That being the case it might be time to think about moving on and getting what you can for this car. If the rest of the car is in real good shape it might be worth investing in a used replacement engine and other ware items but you are going to have to carefully weigh the differences between the two. One thing about totally rebuilding your engine is it should go a long time without any problems. Some might recommend going to the 2.2 liter engine which was preferred over the 2.5 due to less problems.
July 25, 201312 yr I forgot about the differences between the 2.2 and 2.5 liter engines like Rooster2 mentioned. Your engine has major work required to fix it. That being the case it might be time to think about moving on and getting what you can for this car. If the rest of the car is in real good shape it might be worth investing in a used replacement engine and other ware items but you are going to have to carefully weigh the differences between the two. One thing about totally rebuilding your engine is it should go a long time without any problems. Some might recommend going to the 2.2 liter engine which was preferred over the 2.5 due to less problems. With 235K miles on the odo, I don't feel that there is a good reason to rebuild that motor. Just too many miles on what has to be a tired engine. Better off installing a lower mile 2.2 motor as a replacement. That is what I did on my wife's 98 OBW. Car runs great on a '95, 2.2 motor.
