crank pulley bolt
I don't know how, but my crank pulley came off and the bolt is gone with the wind. I'm at the jy now but they don't have any ea82s here. Will one from an ej22 work? If not does anyone know what size and thread so I can go to the bolt store and buy one?
EJ bolt is too long.
Though you could cut one down.
Think it's m14x1.25......not sure though.
Definately needs to be very high grade whatever size it is.
Its the same thread though? How much do you think I'd have to cut off? Or could I just space it out with washers temporarily?
Cut my be difficult. Temporarily spacing would probably be acceptable.
I have one in tacoma you can have for a sixpack of hamms if you can get out here
maybe the torque will push it out anyway...
try a bolt from other ea82... if you can look in some place...
I might be able to get there tonight.
ill be home by 530 tomorrow (wed) sorry wasnt on the board all day
If you do end up having to cut a bolt, try sticking a screwdriver in the hole and mark the length you would need, cut a wee bit shorter than that. Hopefully you can find a straight replacement, though, of course.
a spaced ej bolt whould work i probly have ten on the floor 12/1.25 i think may be wrong by 1/34 inch somthing like that
you might be able to get the bolt by the head size. it's a 22 mm  socket. if you find one, you might want to add some lock thread. small tube you can get at any auto parts store. runs about $3-5$. drip on threads prior to install. then torque to specs. hope this is helpful.
