August 18, 201312 yr I don't know how, but my crank pulley came off and the bolt is gone with the wind. I'm at the jy now but they don't have any ea82s here. Will one from an ej22 work? If not does anyone know what size and thread so I can go to the bolt store and buy one?
August 18, 201312 yr EJ bolt is too long. Though you could cut one down. Think it's m14x1.25......not sure though. Definately needs to be very high grade whatever size it is.
August 18, 201312 yr Author Its the same thread though? How much do you think I'd have to cut off? Or could I just space it out with washers temporarily?
August 19, 201312 yr I have one in tacoma you can have for a sixpack of hamms if you can get out here
August 19, 201312 yr Cut my be difficult. Temporarily spacing would probably be acceptable. maybe the torque will push it out anyway... try a bolt from other ea82... if you can look in some place...
August 19, 201312 yr Author I have one in tacoma you can have for a sixpack of hamms if you can get out here I might be able to get there tonight.
August 20, 201312 yr If you do end up having to cut a bolt, try sticking a screwdriver in the hole and mark the length you would need, cut a wee bit shorter than that. Hopefully you can find a straight replacement, though, of course.
August 20, 201312 yr a spaced ej bolt whould work i probly have ten on the floor 12/1.25 i think may be wrong by 1/34 inch somthing like that
August 27, 201312 yr I don't know how, but my crank pulley came off and the bolt is gone with the wind. I'm at the jy now but they don't have any ea82s here. Will one from an ej22 work? If not does anyone know what size and thread so I can go to the bolt store and buy one? you might be able to get the bolt by the head size. it's a 22 mm socket. if you find one, you might want to add some lock thread. small tube you can get at any auto parts store. runs about $3-5$. drip on threads prior to install. then torque to specs. hope this is helpful.
