How dom I reset ERG dash light that pops on every 60,000 miles?
Hi,
I have an 85 Subaru GL Wagon.  Recently the EGR Light came on at exactly 180,000 miles.
There is a way to reset it, Can anyone explain how?
Edited by chipmunk34
If it stays on, you should be attempting to read the trouble code on the hidden computer above your knees. And do it before you turn off the engine. I was not aware of any red dash light that comes on automatically at any particular mileage, without there being some kind of issue. I have an 86.
I had taken a speedo apart for an 85/86 instrument, and there is a little switch built into the speedo head that trips the light after so many 30 or 60 thousand miles. I suppose it is possible to disable this feature.
Some early carbed EA82's will have just a EGR system and not a ECS.
I may be wrong on the color of the plug, it could be blue.
But if you search the forums, you will find info about it.
http://www.ultimatesubaru.org/forum/topic/93255-86-brat-egr-light-reset-question/
http://www.ultimatesubaru.org/forum/topic/72527-egr-light/
SUCCESS!!! Problem solved!!!
Thank you TURBONE for the links you sent me.  In order to reset the EGR light on your dash, I went above the fuse box
way up there, there is a blue wire connected. Right next to it is a green wire dangling (Of the same size).  I simply disconnected the blue wire
then plugged in the green wire.  Put everything back together and the EGR light was off!  By plugging in the green wire I reset
the EGR light to turn on in another 60,000 miles from now.  Very little room to reach in  up there though...But it's fixed!!!
This also fixed my fuse short as well :D  :D  :D
