chipmunk34 Posted September 9, 2013 Share Posted September 9, 2013 (edited) Hi, I have an 85 Subaru GL Wagon. Recently the EGR Light came on at exactly 180,000 miles. There is a way to reset it, Can anyone explain how? Edited September 9, 2013 by chipmunk34 Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 9, 2013 Share Posted September 9, 2013 Should be a 1 wire connector under the dash on the left side of the steering column. Black plug and it should be connected or disconnected to reset. Quote Link to comment Share on other sites More sharing options...
scoobiedubie Posted September 10, 2013 Share Posted September 10, 2013 If it stays on, you should be attempting to read the trouble code on the hidden computer above your knees. And do it before you turn off the engine. I was not aware of any red dash light that comes on automatically at any particular mileage, without there being some kind of issue. I have an 86. 1 Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 10, 2013 Share Posted September 10, 2013 I had taken a speedo apart for an 85/86 instrument, and there is a little switch built into the speedo head that trips the light after so many 30 or 60 thousand miles. I suppose it is possible to disable this feature. Quote Link to comment Share on other sites More sharing options...
Turbone Posted September 10, 2013 Share Posted September 10, 2013 If it stays on, you should be attempting to read the trouble code on the hidden computer above your knees. And do it before you turn off the engine. I was not aware of any red dash light that comes on automatically at any particular mileage, without there being some kind of issue. I have an 86. Some early carbed EA82's will have just a EGR system and not a ECS. I may be wrong on the color of the plug, it could be blue. But if you search the forums, you will find info about it. http://www.ultimatesubaru.org/forum/topic/93255-86-brat-egr-light-reset-question/ http://www.ultimatesubaru.org/forum/topic/93255-86-brat-egr-light-reset-question/ http://www.ultimatesubaru.org/forum/topic/72527-egr-light/ Quote Link to comment Share on other sites More sharing options...
chipmunk34 Posted September 11, 2013 Author Share Posted September 11, 2013 SUCCESS!!! Problem solved!!! Thank you TURBONE for the links you sent me. In order to reset the EGR light on your dash, I went above the fuse box way up there, there is a blue wire connected. Right next to it is a green wire dangling (Of the same size). I simply disconnected the blue wire then plugged in the green wire. Put everything back together and the EGR light was off! By plugging in the green wire I reset the EGR light to turn on in another 60,000 miles from now. Very little room to reach in up there though...But it's fixed!!! This also fixed my fuse short as well Quote Link to comment Share on other sites More sharing options...
