1980 brat performance
Is there anything out there performance wise for a 80 brat? Like cams piston? Heads any of that??
Cams via Delta Cams. Pistons IDK what would fit if it is a 1600 if its 1.8 you can use 1.6 pistons if you can find any or ea82 spfi pistons.  there are a few more things but that brings the price way up to the point where it would more cost effective to ej swap if you have the skills to make it fit in that tiny hole.
Mike
you would only need one cam,if I understand correctly you just talk to delta cams
http://deltacam.com/
Edited by Uberoo
