September 28, 201312 yr i have the 2701 adapter and i am looking for the base to manifold gasket but cant find the correct one that covers the water port online any suggestions on where to look
September 28, 201312 yr You Shall Close that Water port, as I explained in my Weber Swap Writeup, Here: ~► http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ Either with Cold Welding Compound, or Aluminium Welding (As I Did) or you can make a Thread using Helicoil and close it with the Thread of a Headless Screw, ... (etc) ... but there shall not be Water Flow on that area, anymore; with a Weber Carb. (by the way, I think that I already answered your Weber Questions -including this one- in another Weber Carb thread of yours) Kind Regards. Edited September 28, 201312 yr by Loyale 2.7 Turbo
September 28, 201312 yr Author im talking about the hole where the water reached the base of th carb i have a gasket that has a hole in it for the hitachi but the gasket i used when i mounted didnt
September 28, 201312 yr im talking about the hole where the water reached the base of th carb i have a gasket that has a hole in it for the hitachi but the gasket i used when i mounted didnt Yeah.....we understand. What Loyale2.7 was saying is to close that hole with JB weld. Fill it and file it flat. use a regular base gasket provided.
September 30, 201312 yr I had the same problem Lacy, fifuring that coolant needed to be there. mounted the weber and....coolant leak! I drilled and tapped the hole, and used an allen head pipe plug, then leveled it off with JB weld. Done
