Cleaning TPS on '91 Loyale
Still working through the control systems in Rubie Sue to track down the last bit of raggedyness in the engine.
I cleaned the MAF with CRC MAF cleaner last night, again, a little bit of a gain.  In all, we have gone from really raggedy, barely runs to pretty darn close to smooth now.  I am not looking for more power, the 38 or so horsepower it makes now is adequate for around town, I just want it to pull through the gears smoothly.
New parts/fixes to date:
new plugs and wires
new rotor and cap
new fuel filter
set timing
reconnected several vacuum hoses and replaced two sections with new hose
oil and filter
Cleaned MAF
Checked ground on Primary Coil bracket - solid
So, I am thinking that next up would be to clean the TPS, and make sure that I am getting a clean signal from it.  Can I take it apart and get to the potentiometer to clean it?  What exactly is the drill for this?
Thanks in advance,
