November 4, 201312 yr I couldn't find the answer among old posts... I have a 92 legacy L wagon. My horn doesn't work and I've reduced the problem down to the clockspring. My question is: Will a clockspring listed by the seller as "airbag only!!!" work on my airbagless legacy? There was some debate in a previous thread about whether 92s came standard with airbag. This is beside the point since my 92 definitely does not have airbags. Thanks, guys.
November 4, 201312 yr www.car-part.com as a last resort and you can get exactly what you need for cheap.
November 4, 201312 yr Author So i asked the seller the same question. He told me that if it has no airbag, it has no clockspring. Is this true? If so, then what's wrong with my horn. The horn works when jumped to the battery and I've replaced the relay... Well, there are a couple relays in the same area and I bought a new one, swapped it out with both of the relays and tried to honk the horn, neither time did the horn work, so I assume its not a relay problem.
