1999RS Posted November 8, 2013 Share Posted November 8, 2013 Can the heads on a 1999 RS be removed with the engine still in the car? Is SOHC version. Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted November 8, 2013 Share Posted November 8, 2013 not easily, but yes. it helps if you undo the engine mounting bolts on the bottom and at the dogbone on the fire wall, and lift the engine several inches. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 8, 2013 Share Posted November 8, 2013 as-is - it's nearly impossible to do or to do properly. but remove 3 fasteners - the lower two 14mm engine mount nuts and the bolt for the top pitch rod. once that's done jack the engine up a few inches and it's rather easy. Quote Link to comment Share on other sites More sharing options...
