cd45 Posted February 3, 2014 Share Posted February 3, 2014 I am having a hard time getting the Subie started when it is cold outside. Please tell me how you keep the engine warm. I have a magnetic heater on the oil pan but, it doesn't seem to help, still very hard to start when it is cold outside. Quote Link to comment Share on other sites More sharing options...
lombardcowboy Posted February 3, 2014 Share Posted February 3, 2014 Are you sure it's not a bad battery!?!?! Check and replace with a yellow top optima battery if you can.... Quote Link to comment Share on other sites More sharing options...
l75eya Posted February 3, 2014 Share Posted February 3, 2014 what are the symptoms of your car? also what kind of car? Quote Link to comment Share on other sites More sharing options...
NorthWet Posted February 3, 2014 Share Posted February 3, 2014 +1 on symptoms and car details. You can get a screw-in block heater that takes the place of the right-side cylinder block's coolant drain plug. Should be relative cheap... $30-40. 1 Quote Link to comment Share on other sites More sharing options...
cd45 Posted February 4, 2014 Author Share Posted February 4, 2014 My car is a 1987 GL Wagon. I have not had trouble before this year. I have a heater on the oil pan but, it doesn't seem to be helping. It could also be that the engine really needs an overhaul. I plan to do that in the spring, just need the car running now because of the weather. More snow in Oklahoma this year than in a number of years. The Nissan pickup does no good in the snow and ice. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 5, 2014 Share Posted February 5, 2014 Carb or fuel injected? Quote Link to comment Share on other sites More sharing options...
silverback Posted February 5, 2014 Share Posted February 5, 2014 (edited) The oil pan is too far away from the block for an oil heater to do much good. You also do not want to 'cook' the oil with a 'hot spot'. Is the GL parked outside or inside? What oil viscosity are you using? Is it possible to use 2 trouble lights, 60 Watt bulbs & metal reflectors, inside the engine compartment while at home? What do you do when you park it at work? Please do not use starting fluid. Edited February 5, 2014 by silverback Quote Link to comment Share on other sites More sharing options...
cd45 Posted February 6, 2014 Author Share Posted February 6, 2014 (edited) It is carbed and parked outside. I have not used starting fluid. I use 10-w30 oil. The heater i use is only 200 watt. It stays parked outside while at work as well. Edited February 6, 2014 by cd45 Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted February 7, 2014 Share Posted February 7, 2014 Fix the choke or clean out the carb. It should have no trouble starting until the temp is below zero, so something is broken and heating it is an expensive bandaid. Pump the gas pedal a few times before starting and see if that helps. Quote Link to comment Share on other sites More sharing options...
