99ImprezaOSport Posted February 19, 2014 Share Posted February 19, 2014 So at 283K seems the right wheel bearing is shot. Not in a good state since when I jacked up the car and tried to turn the wheel, it was not so easy to spin. Yes, it was out of gear... I didn't hear too much crunchy crunch so I have work this weekend. Who makes the Subaru bearings for that 1999 Impreza KOYO? NTN? Any suggestions for one over the other? Since I have the bearing heating up pretty good should I replace the hub and/or the knuckle too? GREAT USELESS INFO - OVER 231 MILLION with the standard 205 60 R15 tires that bearing has made 231,211,000+ revolutions Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted February 19, 2014 Share Posted February 19, 2014 Pop a new bearing in, it should be fine. A used knuckle is a commonly used option if you can get to a junkyard. I don't remember the brand off-hand, buy either of those is probably a good bet. Maybe someone else knows for sure and will post. I got one for my car from rockauto. It was one of the middle price range brands. But I made sure to get one that was rubber sealed. The inner half of the bearing failed because some dirt got in it when I changed the axle about two years before. New bearing with seals built in means no dirt gets in it if I have to change the axle again. Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted February 19, 2014 Share Posted February 19, 2014 make sure the brake caliper isn't dragging. Quote Link to comment Share on other sites More sharing options...
99ImprezaOSport Posted February 20, 2014 Author Share Posted February 20, 2014 make sure the brake caliper isn't dragging. Interesting thought there. I rode home today from work and didn't use the brake pedal at all, just the E-brake. Didn't have any horrible shaking. Going to try it again tomorrow. Never have had a caliper "lock-up" while driving or cause any problem like this before (25 years of driving) I do notice a little movement when I lift the right side (passenger) front wheel and rock top to bottom. I have some side to side play but the steering rack unit is a little sloppy. Figure as with all things 283k wears on all parts, especially the suspension. Quote Link to comment Share on other sites More sharing options...
