February 23, 201412 yr 95 wagon a/t awd, 2.2 , transmission fluid leaking alot right above catalytic converter, just started , if i take the plate off , what hoses ? or seal ? any help ? thanks, leaking at the second catalytic converter, right behind transmission Edited February 23, 201412 yr by 86subaru
February 23, 201412 yr Most likely a the drive shaft seal in the tail shaft housing. Just have to clean it up and then find the leak.
