Clutch
My clutch is all screwed up under the dash and would be an easy fix if i knew how it's suppose to look, i'm told that every model is different, so if someone out there would be so kind and to get a picture of what the clutch looks like under the dash in an 83 wagon gl that would be great!
My clutch is all screwed up under the dash and would be an easy fix if i knew how it's suppose to look, i'm told that every model is different, so if someone out there would be so an 83 wagon gl that would be great!
I am guessing you are talking about where the clutch cable mounts to the pedal cluster?
howabout carls brat? 84 and 83 should be mostly the same?
its more like the brass looking round things that are on the cable that snap into a metal holder? or something simular like that. because right now you could push the clutch and it won't even pull the cable. but if you want head on over here with carl and his brat, we'll check it out.
All EA81's I've ever seen were the same down there.... at least Subaru only lists one part # for the cable.....
There's a cir-clip down there that holds the pedal and bushings onto the box... remove that and you can take everything apart. There's a metal pin with a push-on style retainer that holds the pedal to the cable itself. I've seen those pin's worn pretty badly before... maybe that fell out or broke.
