MOcen Posted March 20, 2014 Share Posted March 20, 2014 (edited) I have changed my spark plugs to iridium however my fuel consumption is still high.I have just acquired the car and it has done 130,000KM. Edited March 20, 2014 by MOcen Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted March 20, 2014 Share Posted March 20, 2014 How bad is it? You should be able to get around 24-28 mpg. 10-12 km/l Poor fuel economy can have several causes. Dirty air and fuel filters. Worn spark plugs, old/clogged PCV valve, dirty/clogged fuel injectors. Low tire pressure, incorrect tire size, or sticking/dragging brakes will hurt fuel economy as well. Quote Link to comment Share on other sites More sharing options...
MOcen Posted March 21, 2014 Author Share Posted March 21, 2014 (edited) My full tank is doing about 350Kms.Its doing about 5-6 Km/L. I did also change my tires from the original 205/70/R15 to 215/70/R15.The new tires are taller and am starting to get worried they slowed the car abit thus affecting the fuel consumption negatively. I did service recently and changed the Air Filter,I was also thinking of changing the fuel filter to a new one soon hoping to get better fuel economy. Please advice should i go ahead and switch the tires to 215/65/R15 these seem normal height and make the car more stable. Edited March 21, 2014 by MOcen Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 21, 2014 Share Posted March 21, 2014 (edited) changing the tire diameter away from stock will affect the odometer (and speedometer)n by a few percent. The math for mileage will be affected. For instance, larger tires means you've gone farther, and gotten better mileage, than the odometer indicates. But, it may be possible to get good calculations using GPS readings. a bad Engine Temp Sensor may not create a failure code/check engine light but cause the car to run 'rich'. The ECU also stores the Fuel Trims. If those can be retrieved with a scan, it may offer some clues at to whether the ECU is reacting to a failing sensor by pumping in more fuel. Remove as much weight from the car as possible. Do not carry tools or any other gear you don't need. Edited March 21, 2014 by 1 Lucky Texan Quote Link to comment Share on other sites More sharing options...
presslab Posted March 21, 2014 Share Posted March 21, 2014 Check the toggle rate on the upstream O2 sensor. Or if that's too complicated you can just replace it with a new one. Do the tires wear funny? Check wheel alignment and pressure. Quote Link to comment Share on other sites More sharing options...
robm Posted March 21, 2014 Share Posted March 21, 2014 5-6 km/L is really bad. Is this short trips around town, or on the highway, warmed up? O2 sensor is a good bet, and fairly cheap. Sticky brakes? Check how warm they are after driving normally for a few miles. Check if one wheel is hotter than the others. Fronts are usually warmer than rear brakes. Is the air conditioning working overtime? Quote Link to comment Share on other sites More sharing options...
MOcen Posted March 22, 2014 Author Share Posted March 22, 2014 5-6km/l is on the short trips,I have not been on a highway with it.I will also check out the brakes and see if they are sticky. My air condition is not working overtime,I use it once in a while. I will go ahead to replace my 02 sensor,we do have an NGK distributor in the country where i will buy one. My tire pressure and wheel alignment are fine i did them recently when i bought new tires.I will have a mechanic look at the Engine Temp Sensor. Let me replace the 02 sensor,Fuel Filter and check the brakes too.I will keenly observe the fuel consumption after these repacements. I appreciate all the expert advice and tips you have given me so far. Thanks, Micheal. Quote Link to comment Share on other sites More sharing options...
