March 21, 201412 yr I have found a 5 speed duel range, out of a 85 gl wagon, can i change the gear ratio to what my car is-4-11 I think,or is it better to get the rear end also. I would like the lowest ratio I can get.
March 21, 201412 yr It is possible to change the ratio in a 5 speed dr box to 4.11 but it is alot of work and mismatching parts.My comparison changing the rear diff ratio is 10 bolts that are fairly easily accessed.
March 22, 201412 yr And , this answer has been given way to many times. That is a simple search question. The FAQs at the top of this forum and others lead to a ton of information. I only say this because it is true.
March 23, 201412 yr 5 Spd Duel range Does it count to 10 miles then the gears shoot eachother? LOLOLOLOLOLOOLOLOLOLOLOLOl
