April 8, 201411 yr The car starts fine, no lights flashing, idles low, shifts late and harsh, and also won't shift to fifth gear, can someone help me please I'm new to the subi game and need help ASAP!
April 9, 201411 yr Author when in fourth it sounds like it wants to shift, but then the at oil temp light starts flashing, what is shift mapping?
April 9, 201411 yr when in fourth it sounds like it wants to shift, but then the at oil temp light starts flashing, what is shift mapping? What do you mean "sounds like" it wants to shift. Does it rev up without going any faster? Or just in very high RPM range? What are the RPMs of the engine at 60 mph?
April 10, 201411 yr Sounds like torque converter is not locking. Toghether with Flashing AT Temp light could mean bad lock up solenoid .(B?) Pulll Codes
April 10, 201411 yr How to read transmission codes:http://www.ultimatesubaru.org/forum/topic/113278-how-to-read-transmission-codes/
April 11, 201411 yr Author the temp light flashed twice, so does that mean the solenoids are good and the problem probably lies with the torque converter?
April 11, 201411 yr have you checked the fluid? Keep the engine idling on level ground, shift to each individual gear for 10-15 seconds, then to Park. Keep idling, pull the dipstick and wipe it. wait 2 minutes. seriously, wait. Check the level.
