April 25, 201411 yr Sounds like HLA Noise, bouncing ideas around before i dive in. Your Thoughts? http://youtu.be/tklkP5Ooysg Edited April 25, 201411 yr by Subeast-EA81
April 25, 201411 yr Author Just in case anyone asks, i did search, and am certain HLA noise is what i think, just need some reassurance (Daily driver = Fix on weekend = limited time to repair)
April 25, 201411 yr Well, yes, that is hydraulic lifter noise, might be some more noises in there as well. How long has it been like that? Just buy it, suddenly develop? You going to dive in and do what ? I would check oil level, oil pressure, oil quality, oil supply and pot compression first before diving in to replace them with new or reco HVLA's
April 26, 201411 yr Author Thanks fellas, this isn't my first rodeo by any means, but when it comes to an internal noise i have never trusted my gut, as for the oil and pressure and what not, the oil is fresh along with a bosch filter, up to proper lever and running about 40 lbs at an idle warm. I did replace 6 of the 8 HVLA's when i pulled the engine for top end overhaul, so maybe one of the two that did test good might be on the blink. Ill update when i decide to dive in (dive in I.E remove cam towers and check, file and massage where needed)
