May 17, 201411 yr Hi all! Going to repaint my front bumper and i need to temporarily remove my Bar. Here's the pic of how it's mounted. Now the question; can i remove those bolts (2 on each side) without the crossmember dropping off or do i need to brace it up? I've loosened it a bit and the crossmember seems to want to drop. http--,,--//
May 18, 201411 yr You'll want to put a jack under the center of the crossmember. The nuts will come off, but the bolts will stay in place.
May 18, 201411 yr Author Yeah, that was my thinking. Except it had a bar mounted skid plate that partially mounts to the crossmember and I'm having a heck of a time getting the mounting bolts (on the bar) off. Think I'm gonna have to drill them out. thanks, you did answer my question.
