oil pump project
So I started on pulling apart my ea82 to replace the gaskets and seals for the oil pump and it got to dark out to continue. I have the pump off and wondering if I pull off the pully or the pump end?
You don't have to pull the pulley to pull the pump.  The pump should wiggle out with the pulley on it.  It took me forever to figure it out the first time since I thought the pulley had to come off first.
This is where I'm at its off but need to know what side to pull for the shaft seal. Well I guess I can't upload my picture but it's sitting in a box in the kitchen
Edited by drake13
soft vise the impeller then remove pulley bolt and pulley. shaft then comes out. hth
Thanks for the help subruise I have the new seal in and gasket on. About to get the rotten bastard back together.
