August 19, 201411 yr I just bought a Crosstrek XV Hybrid over the weekend and I enjoying it. I listen to both radio and music via Bluetooth. The audio quality via Bluetooth is amazing and very loud and clear. The audio quality via radio is horrible and very soft and full of static. Does anyone has the same problem or is it just my car having the issue? I don't HD quality audio but it was horrible and not even close my old car. Thanks and appreciate any advice.
August 20, 201411 yr Maybe you're just in an area where there's bad reception. I've never heard of this happening other than for that reason. I would call the dealership. . .
August 20, 201411 yr Author Thanks, I will ask the dealership to check on it during my initial servicing.
August 21, 201411 yr Aftermarket head unit or all stock? It sounds like the fm antenna booster is not connected or is not working.
August 21, 201411 yr Nope its not the radio. Its the programming of it. Search for "Subaru Radio Hidden" on Youtube. There are buttons to hold down that change the sound quality. Not sure why Subaru did it this way.
August 22, 201411 yr Author It is stock radio and I have tighten the antenna. I just saw the tips on YouTube to increase the sounds quality for radio and will give it a try.
August 22, 201411 yr Author I followed the instruction on YouTube to enable "Through Mode" and it sounded so much better. It cannot be the same as CD or BT audio quality but so so much better. So basically, if you don't want to watch the video, press key 1, 4 and audio button together to enable "through mode". It will appear on the screen. Turn it on and you will hear the different in audio quality.
September 1, 201411 yr It's strange that it's possible to chage sound qualiy like this. Why wouldn't it be on the best settings at the first place
October 5, 201411 yr It's a bummer this isn't even in the car manual, I have the same problem, will be trying this now to see if it fixes. Mostly I noticed the highs are greatly suppressed. Edit: I had to watch the youtube video, you have to press one and 4 and the tuner knob when the deck is turned off, with key in accessory position. Edited October 5, 201411 yr by Mr. Carb
May 10, 201510 yr I am having bad reception on the fm with the starlink 7. Seems similar to the complaints mentioned here. Brought it to the dealer. They said they couldn't see a problem. I can't listen to the radio stations I hear well in every other car. Seems like the antenna lacks power. Any suggestions?
July 21, 201510 yr Otterjeanne1, is you Crosstrek a hybrid? I havethe same problem. And no buttons to set as the above posters mentioned. I'm sodiscussed, I paid for a premium sound system, and can't use it where all myfriends jam to their standard systems....I have contacted 2 dealer that won’teven look at it. And A lemon law attorney who says radios are too difficult ofa case. The salesman knew how important the sound system was in my buyingdecision....Subaru customer service told me it's very acceptable for me not to get reception where other cars do,because it's a hybrid. What the Hell are they putting premium sound systems ina vehicle where it won’t work?
October 28, 201510 yr My 2014 Crosstrek is at the dealer for the 4th time regarding this. I have had loaner cars: another Crosstrek, Forrester & Impreza that have the same sound issues, (static and low volume). Starting to think it is a Subaru problem not a faulty radio. I tried the video mentioned above but it didn't do anything on mine. Anyone have success resolving the static?
October 29, 201510 yr I found out it's just intentionally bad by design, to encourage people to upgrade to the HD radio for the car. the 2015 comes with it stock and sounds a heck of a lot better, I wonder how much it would cost to just get the radio and swap it out. I too have a 2014 with the bad radio quality and given it's worse than pulling teeth to get Carter Subaru in Shoreline to aknowledge any defect in the car, I gave up and started taking it to a third party shop and paying to fix it the issues I had (except the radio).
October 29, 201510 yr I found out it's just intentionally bad by design, to encourage people to upgrade to the HD radio for the car. the 2015 comes with it stock and sounds a heck of a lot better, I wonder how much it would cost to just get the radio and swap it out. I too have a 2014 with the bad radio quality and given it's worse than pulling teeth to get Carter Subaru in Shoreline to aknowledge any defect in the car, I gave up and started taking it to a third party shop and paying to fix it the issues I had (except the radio). I have the HD model and it still sounds bad. I am wondering if it is the antennae?
November 1, 201510 yr A lot of this simply sounds like reception issues with the antenna. Today's antennas are so small and insignificant that reception of radio waves is probably not nearly as good as the old-fashioned ones that stuck out straight up rather than being slim and unnoticeable. Anyone considering changing their antenna to an old-style one? I personally don't use the radio except for road/weather condition advisories.
September 11, 20178 yr I have a '14 Crosstrek and at 38k miles the screen was flashing white or breaking up. The dealer replaced as a courtesy, now 4 months later the power keeps going out. It justs off then comes back on. I had the wiring checked today and they could find nothing wrong, told me it may be the actual radio but I may have to replace the backup camera too unless there is a harness where they could connect to the new radio??
