October 23, 201411 yr I have 2003 outback wagon 2.5 with about 170,000 on it. The steering wheel slowly oscillates back andforth at slow speeds, 25 and under and stops at speeds higher than that. There is also a cv joint knocking, soundslike inner passenger side to me. Couldthese two things be related or is the oscillation a separate issue? Also I have replaced axle shafts on a number of outbacks upthrough 1999 model year. Is the 2003 prettymuch the same procedure or will it be different in some way?
October 23, 201411 yr Sure could be one and the same. Good visual inspection is the place to start Tire Pressure Tire Tread Lug Nuts and Wheel Brake Rotor Brake Caliper and Pads Axle
October 24, 201411 yr 03 will have the same process for axle change. The wheel wobble could be an axle issue, but check tread wear on the tires for any low spots. Also grab the wheel at opposite sides and top and bottom and try to rock it back / forth and in/out to check for any loose movement.
October 24, 201411 yr i would think tires first. how old are they and condition? but given a known issue it's good to start there. www.car-part.com and look for OEM Subaru used axles - green inner cups.
