October 29, 201411 yr Is there a way to bypass the O2 sensor? Do I even need it if I'm installing a Webber?
October 29, 201411 yr Author That's what I figured, but if I don't hook it up won't my ECS light stay on?
October 29, 201411 yr Gloyale, or anyone else reading this. Could you explain why you don't need the O2 sensor if you have a weber? I'm a mechanical noob and trying to learn.
October 29, 201411 yr Remove the computer and throw it away. You have a weird model that used a computer and some solenoids to alter the mixture by increasing or decreasing the amount of air allowed to mix with the fuel. Most of these systems don't work anymore.......and the Car will still run with the ECU unplugged. And then If you install a weber.......you will be removeing all the stuff that the ECU controlled anyhow. Ditch it all. The on;y wire that the weber needs is 12v "key on" power to the electric choke.
October 29, 201411 yr http://www.ultimatesubaru.org/forum/topic/86889-whats-up-with-the-bad-mileage/?hl=%20fuel%20%20mixture%20%20meter This is the only reason for an O2 sensor with a weber.
October 29, 201411 yr Author Ok cool. Thanks. Wow, ditch the whole computer. Makes sense. Once theemissions are gone I can't think of anything it would be controlling.
