November 6, 201411 yr How do you gain access to hatchback latch assembly that is loose and Making a rattling sound?
November 7, 201411 yr Welcome to the USMB. Can you please let us know what year and model you have. Thanks
November 7, 201411 yr year and model would be very helpful, but in general, the plastic trim panel on the inside of the hatch will need to be removed to gain access.
November 7, 201411 yr Pull the plastic cover around the bottom Hook Loosen the two 12 mm bolts Take a block of wood and hammer and give it a good wack You can move it in about 1/8-1/4" Tighten the Bolts Put it back together
