May 16, 200421 yr hey all, got the Weber on (32/36 DGEV on ea81) and have some plumbing questions. I've read and seen the pics from the board and still have questions on ID'n which line is which. Are the fuel-in lines 'wet and return lines 'dry'. Also what that about stopping the return line at the firewall??!? Also, I understand theat a feul pressure regulator in needed, true?! if so where does this plumb in?? any help appreciated, I'm half finished here and need help!! thx all, ShanonSF 82 GLW
May 16, 200421 yr See your last post on this for the return line thing. I answered it there. As for a pressure regulator, no you don't need one. The reccomended pressure for the weber is 4 psi. The stock pump only puts out 1.35 - 2.06 psi. Thus a pressure regulator is a waste of time. GD
