December 10, 201411 yr Hi everyone, My '85 DL is in need of some fresh rear wheel bearings. I am a little bit confused on what I see on Napa/RockAuto as to what part(s) I need. I see there is an inner and outer bearing. Napa shows the inner and the outer which are below: Inner: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Inner-Rear-Wheel/_/R-BRGBR30206_0141319794 Outer: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Outer-Rear-Wheel/_/R-BRGBR30204_0141319795 Then Napa also lists this bearing... Is this both inner and outer combined?? http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 I also read that I should buy both inner and outer replacement seals. From what I see, they don't come with the Napa bearings. Any idea where I can get those and what the part # would be? Thanks! Craig
December 10, 201411 yr http://parts.subaru.com/a/Subaru_1985_DLGLGL10RSRXDL-WAGON/_54106_6024626/FRONT-AXLE/A10-280-A1.html
December 10, 201411 yr Author http://parts.subaru.com/a/Subaru_1985_DLGLGL10RSRXDL-WAGON/_54106_6024626/FRONT-AXLE/A10-280-A1.html Thanks. That is for the front. I am trying to click to access the rear axle set up but the site won't let me...It keeps showing front components.
December 10, 201411 yr Hi everyone, My '85 DL is in need of some fresh rear wheel bearings. I am a little bit confused on what I see on Napa/RockAuto as to what part(s) I need. I see there is an inner and outer bearing. Napa shows the inner and the outer which are below: Inner: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Inner-Rear-Wheel/_/R-BRGBR30206_0141319794 Outer: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Outer-Rear-Wheel/_/R-BRGBR30204_0141319795 Then Napa also lists this bearing... Is this both inner and outer combined?? http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 I also read that I should buy both inner and outer replacement seals. From what I see, they don't come with the Napa bearings. Any idea where I can get those and what the part # would be? Thanks! Craig Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number Edited December 10, 201411 yr by mikaleda
December 10, 201411 yr Author Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number Ok, great! Thank you! I am on NAPA's website and I don't see them showing the seals at all?
December 10, 201411 yr Ok, great! Thank you! I am on NAPA's website and I don't see them showing the seals at all? Give them a call their more than likely going to need to look it up in the book
December 10, 201411 yr Author Give them a call their more than likely going to need to look it up in the book That I will do. The I just moved so I am HOPING this Napa has a little bit more enthusiasm than the last. The last Napa I dealt with would look in there crappy computers and say, "nah, we don't got it". In most cases I would have to search for part #'s. Thanks legacy specialist for the info. I'll be huffing and puffing to do the rear bearings this weekend. Wish us luck!
December 10, 201411 yr Author Yes these are the rear wheel bearings. The first option is like the original two peice style and the latter is the newer style one piece race. Both styles will work just fine Yes always replace seals, Napa should have the part number In your opinion, would you say that the upgraded rear bearing shown in the link above make for an easier install? Also, I am still a tad bit confused. So this bearing in the link below: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 This bearing is the inner? I will still need to purchase the outer? I am on Rockauto.com and only see the new style inner bearings. The outer rear bearings for sale are all for front wheel drive Subi's.... Edited December 10, 201411 yr by stoogesman
December 11, 201411 yr In your opinion, would you say that the upgraded rear bearing shown in the link above make for an easier install? Also, I am still a tad bit confused. So this bearing in the link below: http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Wheel-Bearing-Rear-Wheel/_/R-ATM2123001_0418666376 This bearing is the inner? I will still need to purchase the outer? I am on Rockauto.com and only see the new style inner bearings. The outer rear bearings for sale are all for front wheel drive Subi's.... That style is the inner and outer it just has one solid race. It is the easier option for installation
December 11, 201411 yr Author That style is the inner and outer it just has one solid race. It is the easier option for installation Thank you so much! My local advance auto has them in stock.
December 11, 201411 yr You have to punch your car back into the system to navigate on there after you click on the link. It's comes in handy even if you don't buy from subaru. Heres the rear. http://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=1985&modelName=dlglgl10rsrxdl-wagon&ukey_assembly=6028557&ukey_category=54106&assembly=a10-281-b1
December 11, 201411 yr Author You have to punch your car back into the system to navigate on there after you click on the link. It's comes in handy even if you don't buy from subaru. Heres the rear. http://parts.subaru.com/showAssembly.aspx?makeName=subaru&modelYear=1985&modelName=dlglgl10rsrxdl-wagon&ukey_assembly=6028557&ukey_category=54106&assembly=a10-281-b1 Thanks stratman977. Where is Belle Vernon, PA? I am in Bloomsburg...
December 11, 201411 yr Wheel seals for the rear of the EA82 4WD are, National Seals numbers; Inner 224015 Outer 225005
December 12, 201411 yr Author I'm an hour south of Pittsburgh, a long ways from you unfortunately. That is quite far. My sister lives in Marysville.
December 12, 201411 yr Author Wheel seals for the rear of the EA82 4WD are, National Seals numbers; Inner 224015 Outer 225005 Thank you TomRhere!
