December 14, 201411 yr Mainly curious if the bell housing is the same off of a EJ 2.0 and the EJ 2.2 And how is the easiest way of telling gear ratio for the transmission
December 14, 201411 yr There are minor differences over the years in the bellhousing, 90-98 are phase 1 4 bolt bellhousing and 99+ are phase 2 8 bolt. There two phases are interchangeable for manual transmission, but not automatic. If you have access to the transmission code a quick google sear have should give you the final drive ratio, you can also post it here as some of the members are handy at reading them.
December 14, 201411 yr Author There are minor differences over the years in the bellhousing, 90-98 are phase 1 4 bolt bellhousing and 99+ are phase 2 8 bolt. There two phases are interchangeable for manual transmission, but not automatic. If you have access to the transmission code a quick google sear have should give you the final drive ratio, you can also post it here as some of the members are handy at reading them. Where would I find the code for the Automatic transmission at? thank you for let me know about the bell housing differences
December 14, 201411 yr This link will give you info on the gear ratio. https://www.dropbox.com/s/1ia75cro4n1deou/TransmissionIDChart_Public.pdf
December 14, 201411 yr There should be a sticker on the transmission, usually near the starter on the ones I've seen.
December 15, 201411 yr There are minor differences over the years in the bellhousing, 90-98 are phase 1 4 bolt bellhousing and 99+ are phase 2 8 bolt. There two phases are interchangeable for manual transmission, but not automatic. . They are all interchangable. In fact Automatics are easier since the lower starter bolt is a stud in the trans case......not one of the through bolts. Manuals the lower starter bolt is one of the 8 bolts in the 8 bolt housing........But one can install a threaded insert into the Trans bell, and use it for a stud for the lower starter bolt (8 bolt trans w/4 bolt engine)
December 15, 201411 yr Show me a phase 2 automatic transmission running correctly in place of a phase 1 without a wiring swap.
