where do these gaskets go?
Okay I'm just curious I'm almost certain I don't need these for my RX Turbo EA82
I'm just curious I'm not even familiar with these gaskets on any ea82 engine
If you could tell me where they going what they are that would be awesome thank you guys
Upper left is a Hitachi carb base gasket and the upper right is a tbi gasket. No clue on top center or bottom two.
I thought the TBI Gasket was more like an o-ring type of material?
I see if anybody else can play the guessing game lol
I think the bottom 2 look like oil fill tube gaskets, the top right looks possibly like a gasket for a turbo or mpfi tb. The tbi used an o-ring. Middle one doesnt look familure, and top left has been identified by skishop.
I believe the center one is an IAC gasket and the bottom two are spider intake coolant crossover gaskets.
Confirming what Caboobaru says above, the bottom two green ones are the coolant transfer gaskets on the lower back section of mpfi inlet manifold  (maybe not spider specific) - very handy for when you replace those small 12 & 14? mm welch plugs at the back.
The large green one looks like spider TB to inlet manifold gasket - they are not same as mpfi non spidey
Edited by jono
Thank you for correcting me. Shouldn't have said tbi. Force of habit. Both my EA82's have spider manifolds so just plain tb. My bad.
I must be brain farting What is spider manifold?
Is that just a fancy way of saying multiport fuel injection
Like my turbo EA82 is
www.google.com
EA82 spider manifold image
shazam!
came on XT turbo and some others ? Looks more an EJ style of inlet manifold over the old shar[p angle old mpfi EA82 inlet.
It is a 4 legged spider not got 8 legs !
Edited by jono
www.google.com
shazam!
Oh yeah I knew that Like I said I was brain farting the older Impreza they had the 1.8 right
I have never seen an XT with that motor I've seen them with the EA82 to multiple fuel injected
Like what's in my 86 rx
