February 19, 201511 yr I've been studying the forums, HTKYSA, and a factory manual to learn as much as I can about my Hitachi and the associated emissions systems. I may have given myself information overload. I have a simple question to check my newly obtained knowledge. My situation: 83 GL wagon, 4wd, may or may not be a California model. The O2 sensor is gone (port plugged). The emissions/vacuum system has been modified by a po. I can't find an ECM. It has either been removed or I simply can't find it. My question: From what I have read here and in the manuals, my hitachi will run rich if it is not receiving feedback from the o2/ECM? I read someplace that the hitachis are jetted rich and the ECM leans out the mixture to suit conditions. The car runs rich. Am I correct in my thinking? The caveat: Compiling parts for a weber swap in a couple weeks.
February 19, 201511 yr ... The caveat: Compiling parts for a weber swap in a couple weeks. Yes, the Weber Swap is Awesome, but in the meantime, you can check your main fuel Jets on the craptachi carb, to be set at ~ 116 for Low stage (Primary) and ~ 140 for High stage (Secondary) then you can forget about the electronic control / vacuum operated High stage (Secondary), and Modify your craptachi carb to have it Mechanically operated, like in the Webers; taking ideas from this Writeup / Video on this link: ~► http://www.ultimatesubaru.org/forum/topic/147163-mechanical-conversion-on-hitachi-carburetors/ Good Luck! ... Kind Regards.
February 19, 201511 yr Generic exhaust often has O2 port, so could be replacement y-pipe on a non-feedback system.
