February 28, 201511 yr Got my heads from my 99 Forester on my work bench right now. Would like to set the tappet clearance before I put the head back on but I cant find the specs. Anyone have this information? Thanks
February 28, 201511 yr Do you have the car? Valve clearance should be on the emissions label on the bottom of the hood.
March 2, 201511 yr When I did the HG on my 00 OBW with SOHC engine last year I had the heads rebuilt. While I had them on the bench I very carefully set the rocker to valve stem clearances. After I got the heads back on the engine the clearances were all wrong. I still don't know why the clearances would change just bolting the heads on to the engine but that was my experience.
March 3, 201511 yr almost positive it's .008 intake and 0.010 exhaust google it? all 00-04 EJ25's will be the same as your 99 SOHC Phase II EJ25.
