March 7, 201511 yr I need help wiring my dual dxm260(I believe that what it is) into my 1987 gl base I've looked online and YouTube's it with no luck please help only the front work
March 7, 201511 yr You have to install your own rear speakers. Also, run your own speaker wire to all four speakers. Don't use the stock wires. If you do use stock wiring you will burn out your radio when you adjust the fade and balance.
March 12, 201511 yr Author Hey um question guys and gals um does any one know how to setup an 83 intake manifold onto an 82 block both are ea81s
March 12, 201511 yr What exactly are you doing? If it is a straight swap, just bolt it on. Use OEM gaskets. If you are using the Hitachi carb - good luck. It can be done. If you are going with a Weber, there is tons of info on this forum. You may want to use an EA82 intake. Guys and Gals ... I am not positve, but it is my belief that this is not the site to meet girls. It's ok to laugh! As long as your car is still running.
March 15, 201511 yr Author spoob any one know how to put my 83 intake and Hitachi carb in to my 82 block
