March 22, 201511 yr What pins on the relay (real picture) correlate with the numbers of the pins in the drawing? Trying to rig up my LED bar and I have a lot of these relays so it'd be very convenient to use these
March 22, 201511 yr The 2 on the left of picture are the coil (equivalent to 85 and 86 of diagrahm) the other 2 are the load (equivalent to 30 and 87)
March 22, 201511 yr Author The 2 on the left of picture are the coil (equivalent to 85 and 86 of diagrahm) the other 2 are the load (equivalent to 30 and 87) Does it matter which I use out of the 2? Like can I just randomly stick what would be 85 on either of the left?
March 22, 201511 yr Coil polarity doesn't typically matter on a relay. It should work either way but you can test it pretty easy with some jumper wire/aligator clips.
