March 27, 201511 yr I am looking for a diagram that illustrates what hose goes where. When I bought my Brat, the fuel line was connected to the bottom of the tank. I found out this is the drain plug from a previous post. I need to know where I should hook up the fuel supply to. Is a factory shop manual available for an 82 Brat?
March 27, 201511 yr the fuel line, the return and vapor should be on the front. exactly where im not sure.. whats it doing underneath like that? has your tank been modified or repaired? also finding a shop manual for old gen cars like these is getting harder and harder to find.
March 27, 201511 yr On the lower front corner of the tank on the passenger side there is 2 barbs one is 5/16ish and the other is 1/8ish the bigger one is the supply smaller is the return.
